Mar 27, 2022Guru - Experienced User
New - CAX80 Firmware Version 2.1.3.7 Released
Security Fixes: 03/23/2022
Fixed security issues.
For more information about security vulnerabilities, visit https://www.netgear.com/about/security/.
Download Link:
https://www.netge...
Jun 18, 2022Guru - Experienced User
Did you factory reset the modem and and setup from scratch after v.7 Fw was applied?
What ISP are you using?
jffwarner0 wrote:
I'm having the same issues with reboots post-update.
From what I was seeing in the logs, it appears to be some issue with the firmware detecting DOS LAND Attacks falsely until it locks up and reboots.
After downgrading the software, the issue disappeared.
Upon re-installing the .7, the issues happen again.
jffwarner0
Jun 18, 2022Guide
I'm on COX, had them come out and check and they couldn't find any issues with any of the wiring.
I did do a factory reset as well before the manual .7 update.
- FURRYe38Sep 20, 2022Guru - Experienced User
FYI:
https://community.netgear.com/t5/Cable-Modems-Routers/New-CAX80-Firmware-Version-2-1-4-2-Released
