Sep 20, 2022Guru - Experienced User
New - CAX80 Firmware Version 2.1.4.2 Released
New Features and Enhancements:
Stability Improvements
Recommended to help prevent any modem bricking's.
Download Link:
https://www.netgear.com/support/product/CAX80.aspx#download...
What does it mean "I have to re-authenticate to the router when it reboots."
I recommend doing a full on factory reset and setup from scratch then save off a new backup configuration to file.
tamanaco
Sep 20, 2022Apprentice
"What does it mean "I have to re-authenticate to the router when it reboots."
RE-ENTER CREDENTIALS -> User ID, Password then Answer two questionnaire question and Continue. After the router reboots due to: Power Cycle, Reboot via GUI or FIRMWARE UPDATE!
"I recommend doing a full on factory reset and setup from scratch then save off a new backup configuration to file."
I did it in 3 ways multiple times as I mentioned in my post.
"Yes, I have factory reset the router using the reset button in the back, using the Revert to factory settings "Erase" button on the GUI and using the NVRAM Reset/Factory Reset process. And reconfigured from SCRATCH."
