Sep 20, 2022Guru - Experienced User
New - CAX80 Firmware Version 2.1.4.2 Released
 New Features and Enhancements:
 Stability Improvements
 Recommended to help prevent any modem bricking's.
 Download Link:
 https://www.netgear.com/support/product/CAX80.aspx#download...
Nov 14, 2022Guru - Experienced User
FYI, New FW is available for the CAX80:
- rlfarrFeb 19, 2023AspirantFURRYe38, Does new firmware 2.1.5.2 cause problems with the early beta CAX80. Thank you. - FURRYe38Feb 20, 2023Guru - Experienced UserIt should not. Mines loaded with it. There was an issue with beta having older boot loader code that would cause a problem with newer FW. I helped test this out with mine and NG fixed it.
