Sep 15, 2024Guru - Experienced User
New - CAX80 Firmware Version 5.1.1.8 Released
New Features and Enhancements: 09/10/2024
Smart Parental Controls
WPS PIN and ReadySHARE Vault support removed
Bug Fixes:
Fixed security vulnerability issues.
Fixed various bugs.
Sep 20, 2024Guru - Experienced User
Who is the ISP that your connected with?
What channels are you using on the modem?
Is Smart Connect enabled or disabled?
Is AX mode enabled under basic wireless settings?
Is MIMO enabled?
Is IPv6 enabled or disabled?
Clintonweb wrote:
Even with this new firmware, I am still having issues sending pictures over 5 GHz, and have to switch to the 2.4 GHz to send them. This is even after a factory reset of the device.
Are there some settings I need to enable or change for the fix?
Clintonweb
Sep 20, 2024Guide
Xfinity/Comcast
5GHz is on channel 36.
Smart Connect is disabled.
Yes, AX is enabled.
Is MIMO enabled?
MIMO is enabled.
IPv6 is enabled.
