Jan 13, 2023Guru - Experienced User
New - CBK750 Firmware Version 4.6.14.4 Released
Security Fixes: 1/12/2023
Fixes security vulnerabilities.
For more information about security vulnerabilities, visit https://www.netgear.com/about/security.
Download Link:
CBR: h...
Apr 14, 2023Guru - Experienced User
Let us know how it runs or if you see problems.
rmarcare wrote:
Finally up and running non beta, thanks FURRYe38 !
- AGLangApr 17, 2023Aspirant
Hi,
just installed the firmware on my CBR 750, and ran into issues. internet slowed down, and became spotty. Going to try a factory reset.
- FURRYe38Apr 17, 2023Guru - Experienced User
How are you speed testing? Wire PC is preferred for speed testing.
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
AGLang wrote:
Hi,
- AGLangApr 20, 2023Aspirant
Speed testing it through wire I get full signal 500/20 Mbps, and originally I had the same when speed testing over wifi, but gradually it slowed down, and depending on what tool you use to speed test, you get different results?
Orbi's own speed test is going at a 100% and indicates a strong connection.
Remaining is 50% of what we're expecting.
- contacted our ISPN, they have no issues with connecting to the router.
- Signal is 100% when testing through wire
I assume it's something related to the wifi settings, again.. https://community.netgear.com/t5/Orbi-with-Built-in-Cable-Modem/CBR750-slow-network-and-disconnects/m-p/2256934#M3371
