WalleProds
Feb 15, 2021Follower
New C7000 AC1900 higher ping than AC1750 Router with ISP Modem?
This issue is driving me crazy. I had an ISP Modem that was connected to a Netgear Nighthawk AC1750 and I was getting 25-30ms ping while gaming, discord, etc. (I have two gaming PCs btw that me and m...
Feb 16, 2021Guru - Experienced User
What ISp router is it?
What speeds do you get hardwired into the C7000?
Are you gaming over 2.4ghz or 5ghz?
Do you have a screen snip of the cable connections page and the event logs?
