Deval79
Jul 10, 2020Aspirant
New Cable Modem router +\- mesh
Frustrated with my Xfinity gateway, slow Wi-Fi, have to reset it because internet keeps dropping. Don’t like paying them monthly to rent a piece of crap equipment. Want to get the new NIGHTHAWK® AX8 8...
Jul 11, 2020Guru - Experienced User
6000sq ft is rather sizable. What I'd do?
Buy a modem seperate from the router. You tend to have more control over updates, firmware, and settings.
Then you can buy whatever mesh system you prefer and add satellites as needed to the system to provide the coverage you desire.
I'd recommend the CM1000 or CM1100 for docsis 3.1 modems.
But something to check out? your signal quality from comcast. I'm not a fan of them but their modems tend to be fairly solid in terms of hardwired connection. If you're dropping both wired and wireless, it might be a signal issue and not a modem/router issue.
