Harunkingcool
Aug 07, 2023Aspirant
New CAX80 has poor cable connection issues.
Hello, I very recently moved into a new place where I decided to buy my own modem router instead of renting one. I picked up a brand new CAX80 from Best Buy and went home to set it up. I plugged the ...
Aug 07, 2023Guru - Experienced User
Power levels are mostly low or too low:
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
Any Criticals, Errors or Warnings seen in the event logs needs to be reviewed and resolved by the ISP. Indicates a signal issue on the ISP line up to the modem.
You have a ton of correctables and un-correctables that should all be mostly zeros.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
- HarunkingcoolAug 07, 2023Aspirant
The power levels seem to be sufficient, but is there anything else I can do before I call my internet service provider?
- KitsapAug 07, 2023Master
Harunkingcool wrote:The power levels seem to be sufficient, but is there anything else I can do before I call my internet service provider?
Disagree. Ideal is between 0 and +1 dBmV.
- plemansAug 08, 2023Guru - Experienced User
Your power levels are low and you have errors in your line. All indicate line problems.
If you can, simply connect the modem right where the coax comes into the home. This prevents wiring in the home from being the issue. And some ISP’s charge if the wiring issue is in the home. So this helps prevent this.If that doesn't help, the ISP needs to check it.
