Lnmayer
Dec 20, 2022Aspirant
New cax80 received wired ports drop internet
I received a replacement cax80 from NG due to bricked unit. The new cax80 was configured. The problem that I am experiencing is that the internet disconnects from the wired ports. The wireless works ...
Dec 20, 2022Guru - Experienced User
Are you using the multi gig port or just the 1Gb LAN ports?
Be sure your using a good quality LAN cable between the modem and wired devices. CAT6 is recommended.
What is the brand and model# of the switch that is connected?
