Lnmayer
Dec 20, 2022Aspirant
New cax80 received wired ports drop internet
I received a replacement cax80 from NG due to bricked unit. The new cax80 was configured. The problem that I am experiencing is that the internet disconnects from the wired ports. The wireless works ...
Lnmayer
Switch is netgear gs316. The fw was the latest version. I will purchas cat 6 cables. I was connecting the switch to the gigbyte port and my qnap through the aggregate ports.
- FURRYe38Dec 20, 2022Guru - Experienced User
Is LAG enabled on the modem?
Does this happen if you disable LAG on the modem?
