cordcutters's avatar
Sep 04, 2020
New CM1200 - self-assigned IP address via Ethernet Connected Laptop - NO Internet
New Netgear user here, hello! Need help please!
Just changed ISP's today (Spectrum to RCN) and with that needed to buy a better modem. Bought CM1200 (running Firmware Version V1.02.02) about 1 week ago and plugged in just today.
Using Macbook Pro laptop connected via Ethernet directly in one of the ports on back of CM1200.
My laptop is choosing a self-assigned IP beginning with 169.254 - which we know does not allow you to connect to Internet.
If I switch to Wifi on my laptop, I can connect to Internet just fine. The other 3 ports in the back of the CM1200 are Ethernet to: AppleTV, Roku, and of course Ethernet to router. Laptop connects to Wifi just fine. And the AppleTV and Roku work as well.
It's just that my laptop cannot access Internet via Ethernet - and continues to set its IP as 169.254.
I've spent almost 6 hours now, on the phone with Apple and my ISP and no one has an answer for a fix.
I understand some may reply with, well if the Wifi works why bother with Ethernet? I get that.
But I don't understand why this is only isolated to my laptop and no other devices Ethernet connected to the CM1200.
I have attached a screenshot of what the Network settings look like.
Does anyone have advice on how to fix this?
Thank you so much!
  • > Using Macbook Pro laptop connected via Ethernet directly in one of the
    > [...] The other 3 ports in the back of the CM1200 are Ethernet to:
       The CM1200 is a modem, not a modem+router.  How many devices were you
    expecting to connect to it?  (Hint: For typical residential service,
    more than one is probably the wrong answer.)
    > [...] and of course Ethernet to router.
       Your (unspecified) "router" would be a good choice for that one
    device to be connected to the CM1200.
       Visit http://netgear.com/support , put in your model number, and look
    for Documentation.  Get the User Manual.  Read.  Look for "LAN ports"
    and "Connect Your Cable Modem to a Computer" (and the "Note" there).
       You have to admire the oblivion of the author/editor of a User Manual
    for a cable modem which offers advice like:
          For more information, see the cable modem's user manual.
       Most likely, your ISP will provide one external/public IP address to
    your device(s).  If your router is working as expected, then I'd guess
    that the router got it.  After that, I'd expect other devices to get
    less cooperation from your ISP.
       Connect (only) your router to your modem.  Connect your client
    devices to your router.
    • cordcutters's avatar
      cordcutters
      Tutor
      Thank you antinode for the explanation.
      The product literature from the CM1200 Data Sheet as well as product description from the .com site list specs as: Number of Ethernet Ports: Four (4) Gigabit Ethernet ports with autosensing technology - and a Product Diagram which shows 4 of the same yellow color ports at the back of the device.
      I've checked other sites and forums as well; a lot of folks are under the impresstion that the device has 4 equally usable ports, that directly connect the modem to up to 4 devices via ethernet cable, that all can be used at the same time. The fact that that is not true - misleads folks based on product descriptions, data sheets and product diagrams. Before my purchase I spoke with pre-sales dept and they assured me that all 4 ports directly connected to devices, used in tandem. I was pleasantly surprised (at that time).
      I probably could have purchased the CM1000 because we only have 940gig Internet anyway (only bought that speed because of new customer promotion price for 14 mos.) so the CM1200 is not even necessary - and could've saved the $50.
      Appreciate your reply though antinode .
      • antinode's avatar
        antinode
        Guru
        > [...] a lot of folks are under the impresstion that [...]
           Yup.  A Web or forum search for your model number should find many of
        them.
        > [...] they assured me that [...]
           Trust no one, I always say.  It might be true, _if_ your Internet
        service were unusual (multiple IP addresses).  But, even so, connecting
        a typical computer directly to the Internet that way (without a NAT
        router in-between, acting as a firewall of sorts) would be a serious
        security risk.
           If I wrote Netgear's documentation, many things would be different.
    • SPdevotee's avatar
      SPdevotee
      Similar problem I think I ran into.  I think the solution is to not connect additional devices to the CM1200.
      My Netgear AX1800 only has 1 LAN port so do I then need an AP after it to allow mutliple wired connections from the router?
