Grunt66
Oct 23, 2021Aspirant
New CM1200 modem download speed capped at 100Mpbs
Last Sunday (10/17/21) I replaced my Surfboard SB8200 modem with a Netgear CM1200. I had been using the SB8200 since early 2017 when I upgraded my Cox Internet service to 500Mpbs download. The reason...
- Nov 01, 2021
The best option was to use the Arris SB8200 and it works flawlessly. The CM1200 was actually cheaper since I am retired from the military and use the military exchange (retail sales without sales tax) aboard the military base. So the CM1200 was returned and I am using a new SB8200 and download speeds are a consitent 570Mpbs and the light on the front of the SB8200 remains a constant blue color instead of green. I really wanted the CM1200 to work out.
Oct 23, 2021Guru - Experienced User
did you try replacing the cable? I've seen sketchy cables have issues and result in the 10/100mbps connection.
- Grunt66Oct 23, 2021Aspirant
I replaced the CAT 6 cable with a new one and even tried another new CAT 6 cable ( I have various diiferent new CAT 6 cables for other projects) and the issue was still there. I also removed my Router (Asus GT-AX1100) from the equation and connected the modem directly to my PC and the issue was still there. Intresting enough the SB8200 is displaying a steady blue on the front panel indicating it is in 3.1 mode and all tested download speeds are in excess of 500Mpbs.
- plemansOct 23, 2021Guru - Experienced User
Do you have a screen snip of the cable connections page and the event logs?
I've seen ISP's assign different frequencies at times which is why sometimes a reset/reboot/ISP reboot can fix issues for a bit. And then later it goes back to the frequency that is having issues.
- Grunt66Nov 01, 2021Aspirant
