Grwrigh87
Jul 15, 2017Aspirant
New CM400 modem download speed only 30 subscribe to 200
Decided it was time to get rid of Comcast's rented equipment and bought a CM400 modem and AC1750 router. After installing I found that I am only getting 30 mbps download and 6 mbps upload when m subsc...
- Jul 17, 2017
Hello Grwrigh87
Have you contacted your ISP see if they have the modem coded correctly I have seen when someone adds a new modem it gets assigned a basic speed and your old modem has the code for your higher speeds.
DarrenM
DarrenM
Jul 17, 2017Sr. NETGEAR Moderator
Hello Grwrigh87
DarrenM
Grwrigh87
Jul 18, 2017Aspirant
I was just able to make the call today and you are correct. They were still set up to send the blast speeds to the old modem. They removed everything and we started from scratch and this rep activated it properly. Thanks for your response
