almostnotech
Dec 08, 2016Follower
new cm500 up/down leds blinking orange no connection
Hi guys, just bought a new cm500 and lyksys wrt3200. Everything will be working fine when I go to bed, wake up no internet. Up/down stream leds blinking orange, internet light out. Reset the modem, i...
DarrenM
Dec 12, 2016Sr. NETGEAR Moderator
Hello almostnotech
I see alot of T3 and T4 timeouts which is a connection issue I would try removing any cable splitters on your line if that does not fix it you may want to contact your ISP and have them come check your lines.
DarrenM
