bsputnam25
Mar 31, 2020Aspirant
New nighthawk 1750 with existing C3700 cable modem/router
Looking for the least painful way to make a new R6700v2 nighthawk my new wireless router and DHCP server with an existing C3700 cable modem/wireless combo. My existing DHCP config uses class A number...
bsputnam25
Trying to replace the wireless functions of the C3700, have had performance issues and several people have suggested the AC1750 for better prformance, as for the LAN subnet I would like to keep it the same as I have existing.
antinode
Mar 31, 2020Guru
> [...] as for the LAN subnet I would like to keep it the same as I have
> existing.
So long as your new configuration includes only one router, you
should be able to choose whichever LAN subnet you want. But, no matter
to which "class" you think it belongs, if you try to use a subnet mask
other than "255.255.255.0" (old "class C"), then I'd expect problems.
> Trying to replace the wireless functions of the C3700, [...]
C3700 or C3700v2? Look at the product label.
Visit http://netgear.com/support , put in your (actual) model number,
and look for Documentation. Get the User Manual. Read. Look for a
topic like "Change the Router Mode". With "Router Mode: No", the
C3700[vX] should act like a modem-only, leaving the R6700v2 as your only
router.
The alternative would be to leave the C3700 router section active,
and configure the R6700v2 as a wireless access point. Get the R6700v2
User Manual. Read. Look for "Use the Router as a WiFi Access Point
Only". That would/could leave the wireless stuff active on both
devices.
Either way, you should be left with one LAN subnet, which should be
configurable on the active router.
- bsputnam25Mar 31, 2020Aspirant
" if you try to use a subnet mask other than "255.255.255.0" (old "class C"), then I'd expect problems."
You might have just solved my problems right there, currently my mask is 255.0.0.0. I still want to see if I can get the 1750 running, and I did see the change router mode option in my C3700, I'll give those changes a try. Thanks man!
Ok, this is going to sound like a stupid question but if I switch the C3700 out of router mode what local network IP do I use to access it's configuration?
- antinodeMar 31, 2020Guru
> [...] currently my mask is 255.0.0.0. [...]
I can't guarantee that that would be fatal, but it's a safe bet that
these routers were not intended to deal with 16M devices/addresses.
(250 seems to be a stretch in some cases.)> [...] this is going to sound like a stupid question [...]
Nope.
Kasper Gutman : Well, sir, if I told you... If I told you _half_...
you'd call me a liar.Samuel Spade : No, not even if I thought so.
> [...] but if I switch the C3700 out of router mode what local network
> IP do I use to access it's configuration?A DOCSIS modem has a special-case address for that: "192.168.100.1".
(No bets, but I'd expect it to work even if your computer is not on that
subnet.) Worst case: Settings reset, and deal with it as a modem+router
again.
(And that's "its configuration".)
