jefflynn333
Jan 24, 2020Aspirant
*New* Nighthawk CAX80 Release Date?
When will we get a chance to purchase the new Nighthawk CAX80? IS there plans for a CAX1200? Plans for a larger multi-gig port for cable modems like 5-Gig or 10-Gig?
fastroads
Jun 11, 2020Guide
Got a question:
I'm using an R8500 router. If I were to buy the CAX80, is it advisable to get a new seperate router or use the CAX80? Any advantage using a seperate router?
Jun 11, 2020Guru - Experienced User
The CAX is a gateway router and modem thus it already has a built in router and wifi. You can disable the router mode on the CAX and install a external router. Though for the cost of the CAX, i wouldn't see a reason by a expeence modem just to connect a external router.
fastroads wrote:Got a question:
