supertide1
Feb 21, 2024Aspirant
new system
Hi, I have xfinity and they are telling me my modem is outdated. BTW coverage around the house is not good so maybe they are right. (my current situation is a wifi cable modem router model c6300 wi...
Feb 22, 2024Guru - Experienced User
If you have xfinity, don't buy a modem/router combo device.
PIckup a stand along modem. I"d look at their devices that support the "next gen" upload speeds.
https://www.reddit.com/r/Comcast_Xfinity/wiki/knowledgebase/next-generation-internet/
Currently its the Hiltron coda, coda56 (multigig), Netgear CM3000, Netgear CBR750, and Arris g54.
Supposedly they're working on more but those are the current ones supporting the next gen speeds.
Then I'd pickup a mesh system for the home.
If you can possible hardwire in the detached garage or satellites, you could go with a cheaper system like the MK nighthawk or lower priced orbi's. If you can't, then I'd be looking at the triband/quadband versions.
Whats you're budget for this?
Are you able to hardwire in the detached garage either with ethernet or using a MoCa adapter (ethernet over coax).
supertide1
Feb 22, 2024Aspirant
Thank you for the info. Unfortunately I have an older house so hard wiring would be a task. your response helped!
- plemansFeb 22, 2024Guru - Experienced User
do you have coax ran out to the media room in the garage? A moca adapter can get you a hardwired connection out there pretty reliably
