MikeFra
Jan 05, 2017Aspirant
New to nighthawk ac1900
Hello and hope you can help, just got a new nighthawk ac1900 and when searching for router on iPhone 2 come up but when searching by blue ray player 1 comes up. Are both the same speed? Thanks
MikeFra
I have no idea what ssids are and how do you change any of the passwords or network names. Just went from dsl to cable today. Live in the sticks and finally have other isp options. Please tell me what to do. Just called Best Buy cause that's where I got it and they have no idea. Which is faster? The regular network that pops up or the -5g one. My phones and tablets all found 2 and Apple TV also found 2. Please help
IrvSp
Jan 05, 2017Master
There should be TWO different SSID's on the ROUTER unless SMART CONNECT is enabled, then they are the same (both the 2.4Ghz and 5Ghz SSID) with the same passphrase.
From the Router homepage click on WIRELESS on the left side and you'll see all that info.
Speeds are determined by the ISP as far as Down/Up load speeds. Connection speeds are determined by the network adapter in the devices.
More than likely the DVD is only a single speed device and it would then ONLY show the 2.4Ghz SSiD. Meanwhile the iPhone is a dual-band device and it will see both the 2.4Ghz and 5Ghz SSID.
They will both provide the SAME Internet and LAN access speeds, but the major difference is the SIGNAL STRENGTH the further away you are from the router, and the distance the from the router the signal can be seen. In General the 5Ghz SSID will be stronger closeby but will not reach as far as the 2.4Ghz.
