Srchiefret
Jan 01, 2023Aspirant
Newbie. AC1600 WiFi Cable Modem Router
Geni app states “This router does not support remote access”. We travel a lot out of state in our RV and sometimes need to reset or adjust settings for the person taking care of / staying at our ho...
Srchiefret
Can I use the Nighthawk App and get that feature or is my model simply not capable?
thank you!
michaelkenward
Jan 01, 2023Guru - Experienced User
Srchiefret wrote:
Can I use the Nighthawk App .....
It depends on the firmware on your C6250.
Which products support the NETGEAR Nighthawk app? | Answer | NETGEAR Support
See if you can install it and what happens.
Good luck.
