lilpuu
Jul 15, 2019Aspirant
Nighhawk, C6900 WiFi Cable Modem Router
Question on selecting which wifi I should select. On one channel I have a Netgear 5G and the other Netgear15-5G. Is it possible to change wifi from Netgear 15 to Netgear 15-5 without un-installing th...
Jul 15, 2019Guru - Experienced User
Using the modems web page with a browser you an change the wifi SSID name to be anything for each radio. Doesn't have to be the default SSID name that comes with the modem. Change it to your liking.
