Toby2006
Dec 24, 2021Guide
Nighhawk CAX80 Mystery Wireless IP Address
Posted this in the Nighhawk Wifi 6 forum. Recommeded I try here. Under Attached Devices I show a device using IP address 192.168.1.235. It's identified as a phone and connection type is 2.4G Wi...
Dec 24, 2021Guru - Experienced User
Change the PW on the 2.4Ghz radio and see if that device connects or not or someone complains. You'll need to update wifi devices for this radio with new PW.
Toby2006
Dec 24, 2021Guide
"Change the PW on the 2.4Ghz radio and see if that device connects or not or someone complains. You'll need to update wifi devices for this radio with new PW."
Can you explain what you mean by PW? Password?
The thought is to cahnge the WiFi password and see if it still connects? If not I would need to update the password for all the connected devices to the new router password, correct?
