doogiejb14
Dec 11, 2023Follower
NighHawk Voice Cable Modem CM2050V red light flashing on the Multi light
NighHawk Voice Cable Modem CM2050V red light flashing on the Multi light, there is no WIFI
Dec 11, 2023Guru - Experienced User
If the multigig port is flashing amber, it indicates a 100 Mbps connection between router/modem.
You might check the cable and/or the router its connected to.
And like FURRYe38 says, its a modem only device. It has zero wifi capability.
https://www.downloads.netgear.com/files/GDC/CM2050V/CM2050V_UM_EN.pdf
