MTWOODLAND
Mar 09, 2021Guide
night hawk c7100v
Trying to run a 1.gbps signal from comcast, my main CPU is on ethernet. looked up firmware ver. it is up to date ( v2.01.42 ). modem side is DOCSIS 3.0 I got the 1Gig bundle from comcast but the bes...
- Mar 09, 2021
that would explain why the " tier 1 " help desk at comcast wasn't able to load a driver, she didn't explain What Driver, but assume it was DOCSIS 3.1 driver. everything I researched was DOCSIS3.0 would max out at 1Gig...bummer, I would be fine with paying for 1Gig and get 900Meg. the salesman said " for a dollar I would go from 600Meg to 1Gig...
thanks for your help Plemans
Mar 09, 2021Guru - Experienced User
Problem is the ISP. Comcast requires docsis 3.1 for gigabit speeds.
The more people that have been moving to higher speed bundles the more that are requiring docsis 3.1 for those speeds. For example, cox is now starting to require docsis 3.1 for speeds >150mbps.
MTWOODLAND
Mar 09, 2021Guide
- plemansMar 09, 2021Guru - Experienced User
yeah, you can't just "load a driver" to go from docsis 3.0 to 3.1. Its a hardware difference.
Not the first time comcast's tier 1 support has led someone astray.
- MTWOODLANDMar 09, 2021Guide
yes you can hear the pages turning as they try to fine a answer.. Haha..
had one ( " tech" use that word loosely ). that didn't know ethernet conn from wifi conn. I hung up after short while in frustration....
