ronmax999
Sep 06, 2023Aspirant
Night Hawk CM1200 Downstream Blinking
Off and on my downstream led starts blinking and I loose my internet. I have seen some previous posts but I though I would post my connection. Looks like 24 is an issue. Any guidance is appreciate...
- Sep 07, 2023
Have the ISP take a look at the information I pointed too.
Sep 06, 2023Guru - Experienced User
Ok. Most of the time it's an ISP issue.
Let us know how it goes after they complete there work.
ronmax999
Sep 07, 2023Aspirant
After the outage yesterday, today I started losing my downstream at times again. My work computer uses a VPN. When I finally got hold of a Comcast agent and going through all the reboots they blamed it on my VPN. So I said I will disable the VPN this weekend and if it fails then send an tech out. Here are my current logs. what do you think.
- FURRYe38Sep 07, 2023Guru - Experienced User
Power levels are out of spec and way TOO LOW:
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
ISP needs to raise the power here.
I see lots of correctables and UN-Correctables that should be zeros accross all channels.
Lots of criticals as well. Any Criticals, Errors or Warnings seen in the event logs needs to be reviewed and resolved by the ISP. Indicates a signal issue on the ISP line up to the modem.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What is the brand and model of the host wifi router connected to the modem?Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
https://highspeed.tips/docsis-events/- ronmax999Sep 07, 2023Aspirant
Thanks for the reply. The coax to the modem appears to be straight from the pole to the modem. I have the VPN disconnected and the errors have stopped and the download led has been solid. However, the power levels may have something to do with that. I will update this link with any new info.
