ronmax999
Sep 06, 2023Aspirant
Night Hawk CM1200 Downstream Blinking
Off and on my downstream led starts blinking and I loose my internet. I have seen some previous posts but I though I would post my connection. Looks like 24 is an issue. Any guidance is appreciate...
- Sep 07, 2023
Have the ISP take a look at the information I pointed too.
Sep 07, 2023Guru - Experienced User
ronmax999
Sep 13, 2023Aspirant
I finally got a Comcast tech here that knew what he was doing. He put in a ticket and they said that the issue has been resolved. It looks like my power levers are much better and the TV has not paused since. However, I am still seeing uncorrectable errors but no Critical events. Is this normal or do I still have an issue??
- FURRYe38Sep 13, 2023Guru - Experienced User
Yes power is good.
Have you power cycled the modem OFF for 1 minute then back ON or Factory reset the modem then wait about 5 minutes then take a new event log sample?
- ronmax999Sep 14, 2023Aspirant
I just had Comcast fix an issue where my power levels were -18 instead of -7 or greater. However, I am still seeing uncorrectable errors in the thousands. Is this normal or could the modem be going bad? The pic below is right after I rebooted the modem. Thanks for any insight.
- FURRYe38Sep 14, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What is the brand and model of the host wifi router connected to the modem?Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Mod...
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.htmlDoes the modem seem to be working better now?
