agarza
Jul 27, 2019Follower
night Hawk xr500 wont factor reset
I was trying to set up router, was using default access, changed my password and quickly forgot unable to login to set up my router and my router will not factory reset
myersw
Jul 28, 2019Master
Make sure you are holding the reset in for 10 seconds or more or until the lights start flashing. Just poking the reset button does nothing.
