ramjr2020
May 14, 2020Tutor
Nighthawk® Multi-Gig Speed Cable Modem for XFINITY® Voice (CM1150V) MoCA?
A simple question, but I can't find an answer. Does this modem support MoCA? If not, if I set up MoCA adapters, will it work? I understand that MoCA 2.5 and DOCSIS 3.1 may have problems with ov...
- May 14, 2020
No it doesn't.
If you're adding moca adapters they need to be setup off the router.
so CM1150v-----router-----moca adapters
May 14, 2020Guru - Experienced User
Check the sped data sheet to see if MoCa is listed in the specs section, if you don't see it there, I presume the modem may not support it.
- ramjr2020May 14, 2020Tutor
Hi,
Thanks for the suggestion. The problem, not clearly stated, my apologies, is that the technical specs said nothing, and I wanted to be sure it was not just missing by accident ;)
And with the second response confirming your position, I can move forward with my hardware requirements.
