ramjr2020
May 14, 2020Tutor
Nighthawk® Multi-Gig Speed Cable Modem for XFINITY® Voice (CM1150V) MoCA?
A simple question, but I can't find an answer. Does this modem support MoCA? If not, if I set up MoCA adapters, will it work? I understand that MoCA 2.5 and DOCSIS 3.1 may have problems with ov...
- May 14, 2020
No it doesn't.
If you're adding moca adapters they need to be setup off the router.
so CM1150v-----router-----moca adapters
May 14, 2020Guru - Experienced User
Check the sped data sheet to see if MoCa is listed in the specs section, if you don't see it there, I presume the modem may not support it.
ramjr2020
May 14, 2020Tutor
Hi,
Thanks for the suggestion. The problem, not clearly stated, my apologies, is that the technical specs said nothing, and I wanted to be sure it was not just missing by accident ;)
And with the second response confirming your position, I can move forward with my hardware requirements.
