dkhymas
Mar 19, 2020Follower
NIGHTHAWK® MULTI-GIG SPEED CABLE MODEM FOR XFINITY® VOICE (CM1150V) to replace Xfinity Model
Just wanted to make sure if I buy NIGHTHAWK® MULTI-GIG SPEED CABLE MODEM FOR XFINITY® VOICE (CM1150V) and replace the Xfinity Model, that all will work, TV, INternet and PHone without issue and better...
Mar 20, 2020Guru - Experienced User
The CM modem only supports internet and phone services. It doesn't do any TV unless your services are internet based. If you have cable TV services, you still need a cable TV set top box.
dkhymas wrote:
Just wanted to make sure if I buy NIGHTHAWK® MULTI-GIG SPEED CABLE MODEM FOR XFINITY® VOICE (CM1150V) and replace the Xfinity Model, that all will work, TV, INternet and PHone without issue and better?
