JoeCAl
Mar 12, 2020Aspirant
Nighthawk 1150v not compatible with Comcast cable TV
Advised by comcast that 1150v is not combatible with cable tv only voice and internet. I think this should be clearly indicated on all information about modem. The current information indicates for ...
JoeCAl
Mar 13, 2020Aspirant
It works on Comcast cable box but not on Comcast wireless box.
Mar 16, 2020Guru - Experienced User
Thats because the CM modem doesn't have a router or any wireless built in. Again, CM modems are only modems. If you need wifi ability, you need a separate wifi router to connect to the CM modem.
