rge4914
Apr 16, 2020Aspirant
Nighthawk 7000 modem/router can't connect
Cannot connect to modem/router after a 5 hour power outage. Cable company says it's connected and can see the unit. Says the issue is on our end. Yes we been through the normal reset drills. Good wifi...
Apr 16, 2020Guru - Experienced User
Power OFF the modem for 1 minute then back on.
Do you not see the SSID names on any of your devices?
Do wired PCs or laptops get internet?
