NikkeeLasVegas
Sep 04, 2017Aspirant
Nighthawk AC 1900 WiFi Cable Modem Router
Cox has flagged my modem: Service Interrupted; can't identify problem; my unit firmware matches Cox. Problem: connection fails or lags periodically for several minutes at a time; Cox reports no trou...
- Sep 07, 2017
Problem resolved; the problem was "Cox ISP" or the line connection somewhere. Questioned: No details or explanation given for periodic outage and continual scanning for downstream and upstream channels or the continuous error log reporting from my Netgear Nighthawk. All i know is, it wasn't my Modem/router as continually pointed out and suspected from Cox ISP support end. Two technicians were out again yesterday morning and when i got out of the shower, the problem was resolved. Cox won't admit there lack of support online or over the phone, but needless online chat and phone support calls were never acknowledged. Thank you Cox ISP support for the last three weeks of disturbances on my line. :(
NikkeeLasVegas
Sep 05, 2017Aspirant
Thanks for your follow up: Cox is trying to get me to elevate my tier to faster speeds; I don't need because i am not a gamer. I do utilize my WiFi with my Cell, Ooma phone, printer and Smart TV's (Trying to keep it low cost with the ISP). There is a new firmware update out there, but Cox has not released it yet. They are sending a technician out tomorrow to check the signal from the ground box to my house box; blah blah blah, be there done that. Hopefully they will find the problem on the line and fess up to it. Cox's tactics for sales and upgrades is an ongoing issue here in Las Vegas along with Century Link; always pushing bundled service packages i don't need or want. I think this is the ploy and also trying to get me to sign up for a monthly service plan to cover internet issues. -LOL- Cox and Century Link have the market wrapped up here; not much competition here for basic internet services; there is competition for premium T1 and/or fiber, but who can afford the service unless you are a business. :(
William10a
Sep 05, 2017Master
They want you to rent a modem /router from them since the lack of support by isp's for modems made by other then the one they want you to use is common. Arris seems to the most common make used by cable companies in parts of Florida and possible other locations.
- NikkeeLasVegasSep 05, 2017Aspirant
All channels, 16 downstream and 4 upstream are functional with good signal strength. Downstream is flagged "Limited" on both my Netgear unit and Cox online. I believe it's because of the ISP's config and firmware and not my modem. If it ends up being my modem, which i doubt very much, i will replace it with a newer dual band and not rent one. The attached list of accepted Cox Cable modems is huge!
https://www.cox.com/residential/support/cox-certified-cable-modems.html
- William10aSep 05, 2017Master
It could be the firmware on the modem but is the problem even if Netgear has new firmware for the modem the isp has to install it and some do not support every Netgear modem now and since it is not theirs they will not update it sometimes the same reason that you have to a cable box for a tv to receive tv channels you must pay a rental fee to use theirs.
