NikkeeLasVegas
Sep 04, 2017Aspirant
Nighthawk AC 1900 WiFi Cable Modem Router
Cox has flagged my modem: Service Interrupted; can't identify problem; my unit firmware matches Cox. Problem: connection fails or lags periodically for several minutes at a time; Cox reports no trou...
- Sep 07, 2017
Problem resolved; the problem was "Cox ISP" or the line connection somewhere. Questioned: No details or explanation given for periodic outage and continual scanning for downstream and upstream channels or the continuous error log reporting from my Netgear Nighthawk. All i know is, it wasn't my Modem/router as continually pointed out and suspected from Cox ISP support end. Two technicians were out again yesterday morning and when i got out of the shower, the problem was resolved. Cox won't admit there lack of support online or over the phone, but needless online chat and phone support calls were never acknowledged. Thank you Cox ISP support for the last three weeks of disturbances on my line. :(
William10a
Sep 04, 2017Master
NikkeeLasVegas wrote:Cox has flagged my modem: Service Interrupted; can't identify problem; my unit firmware matches Cox.
Problem: connection fails or lags periodically for several minutes at a time; Cox reports no trouble on line but reports bad signal from my modem or line. Only indication i have that there might be a problem with my modem is the continuous downstream and somtimes upstream scanning lights flashing. Continuous scanning; Unable to find any diagnostic or troubleshooting documentation to address this. Does anyone else have this problem on the Cox network and/or is my unit bad? Help!
The isp controlls the firmware placed on a cable modem in your postings device number it is called a r7000 which is a router only so it must be a c7000 if on a coax cable service or a d7000 if on a phone line based service. Can you log into the modem and view its logs and chack its signal levels from the isp service, as a tv cable or phone line could cause problems as far as the firmware version goes your isp is the only one who can update or change settings for their own needs.
stjannifer
Sep 05, 2017Aspirant
Any kind of solution regarding to netgear router setup checkout mywifiext
Thank u
