therealsimpsons
May 12, 2023Aspirant
Nighthawk AC1900 C7000 - 2 SSID are enabled but only one is discovered by the wireless printer
Demographics: Router is hardwired to PC When I open the router and click on "Wireless", it shows TWO SSID, one labeled 2.4GHz b/g/n, "enabled" is checked. The other labeled 5GHz a/n/ac, "enabled" i...
- May 13, 2023
Like microchip8 says, most printers aren't dual band so are only going to see the 2.4ghz band. Thats fine and normal.
did you check with the printer manufacturer?
You might also make sure the ssid/password doesn't have any special characters/spaces in it. I've seen some of the dumber smart devices have issues with special characters/spaces.
May 13, 2023Guru - Experienced User
