Philipthere
Nov 05, 2019Aspirant
Nighthawk ac1900 C7000 drop connection, slow download speed with 5G
Router: Netgear Nighthawk ac1900 C7000 Provider: Xfinity Performance Plus Internet 500 Mbps Problem: Many devices at home drop connection several times during the day, and the connection is on and of...
Nov 05, 2019Guru - Experienced User
When this drop happens, do you notice with wired and wireless devices.
When checking speeds are you wired with a PC for speed testing?
I would open a support ticket here:
- PhilipthereNov 05, 2019Aspirant
Hi, I don't have any wired device. When testing, I use my laptop and iphone.
- FURRYe38Nov 06, 2019Guru - Experienced User
Any Wifi Neighbors near by? If so, how many?What security mode are you using? WPA2 and AES is recommended.
Try enabling WMM.
Test with a wired PC if possible to confirm those speeds are good.
- PhilipthereNov 06, 2019Aspirant
I changed the channel for 2.4Ghz and 5Ghz to the channel that only I'm using, and the security mode is WPA2 and AES. There are many Wifi neighbors near by, maybe around 20.
I find the WMM setting in Advanced ---> advanced setup ---> wireless settings, and both are enabled all the time:
WMM Support (2.4GHz b/g/n) and WMM Support (5GHz a/n/ac)
I wish I could test with a wired PC, but I dont' have any device that can be wired at this time.
