rob_hawthorn
Dec 08, 2016Aspirant
Nighthawk AC1900 C7000 Modem Router Dropping Connection
Model: Nighthawk AC1900 C7000 Modem Router
Firmware Version: V1.01.23
Hi
I'm getting random dropouts to the internet. It's occurring about once every 20 minutes for about 2 minutes each time.
When it happens I run the 'Diagnostics' in the routerlogin.com Advanced panel and I get a successful ping <1ms.
I have had an Xfinity Comcast Engineer out who has confirmed there is a stable connection to them.
I have made the following changes:
- Changed default Admin password
- Changed SSID from default and added WPA2-PSK [AES]
- Disabled UPnP
- Disabled 2.5Ghz (5g only)
- Moved router location (Xfinity Comcast engineer installed to closer location, e.g. 1 meter away).
- Changed default IP
- Switched off remote management
- Ensured the Firmware is the latest
None of the above has made a difference, is there anything anyone would recommend at all? (Thanks for any help).
I need to get this sorted out as I work remotely and this is a big issue especially with video conferencing with clients.
Rob
- rob_hawthornAspirant
Here's the logs, the 'DoS attack' is worrying, how do I stop this?
Description Count Last Occurrence Target Source [admin login] from source 0.0.0.0 1 Thu Dec 08 12:20:42 2016 0.0.0.0:0 0.0.0.0:0 [DHCP IP: 192.168.0.14] to MAC address 6c:40:08:a4:79:58 1 Thu Dec 08 12:20:05 2016 0.0.0.0:0 0.0.0.0:0 [DoS attack: IP packet w/MC or BC SRC addr] from 207.46.134.255, port 443 6 Thu Dec 08 12:16:50 2016 192.168.0.14:60710 207.46.134.255:443 [DHCP IP: 192.168.0.14] to MAC address 6c:40:08:a4:79:58 1 Thu Dec 08 12:09:49 2016 0.0.0.0:0 0.0.0.0:0 [admin login] from source 0.0.0.0 1 Thu Dec 08 12:09:09 2016 0.0.0.0:0 0.0.0.0:0 [admin login failure] from source 0.0.0.0 1 Thu Dec 08 12:09:07 2016 0.0.0.0:0 0.0.0.0:0 [DHCP IP: 192.168.0.19] to MAC address 86:16:f9:c9:51:b4 1 Thu Dec 08 11:51:23 2016 0.0.0.0:0 0.0.0.0:0 [DHCP IP: 192.168.0.19] to MAC address 86:16:f9:c9:51:b4 1 Thu Dec 08 11:51:21 2016 0.0.0.0:0 0.0.0.0:0 [admin login] from source 0.0.0.0 1 Thu Dec 08 11:49:20 2016 0.0.0.0:0 0.0.0.0:0 [DHCP IP: 192.168.0.14] to MAC address 6c:40:08:a4:79:58 1 Thu Dec 08 11:46:37 2016 0.0.0.0:0 0.0.0.0:0 [DHCP IP: 192.168.0.14] to MAC address 6c:40:08:a4:79:58 1 Thu Dec 08 11:44:02 2016 0.0.0.0:0 0.0.0.0:0 [DHCP IP: 192.168.0.14] to MAC address 6c:40:08:a4:79:58 1 Thu Dec 08 11:44:01 2016 0.0.0.0:0 0.0.0.0:0 [admin login] from source 0.0.0.0 1 Thu Dec 08 11:41:53 2016 0.0.0.0:0 0.0.0.0:0 [admin login failure] from source 0.0.0.0 1 Thu Dec 08 11:41:50 2016 0.0.0.0:0 0.0.0.0:0 [admin login] from source 0.0.0.0 1 Thu Dec 08 11:23:03 2016 0.0.0.0:0 0.0.0.0:0 [admin login failure] from source 0.0.0.0 1 Thu Dec 08 11:23:03 2016 0.0.0.0:0 0.0.0.0:0 [DHCP IP: 192.168.0.20] to MAC address 86:16:f9:dc:02:18 1 Thu Dec 08 11:16:34 2016 0.0.0.0:0 0.0.0.0:0 [DHCP IP: 192.168.0.100] to MAC address 86:16:f9:a9:99:39 1 Thu Dec 08 11:12:57 2016 0.0.0.0:0 0.0.0.0:0 [DHCP IP: 192.168.0.19] to MAC address 86:16:f9:c9:51:b4 1 Thu Dec 08 11:11:07 2016 0.0.0.0:0 0.0.0.0:0 [admin login] from source 0.0.0.0 1 Thu Dec 08 11:09:26 2016 0.0.0.0:0 0.0.0.0:0 [admin login failure] from source 0.0.0.0 1 Thu Dec 08 11:09:18 2016 0.0.0.0:0 0.0.0.0:0 [DHCP IP: 192.168.0.11] to MAC address 00:ee:bd:a9:99:39 1 Thu Dec 08 11:07:15 2016 0.0.0.0:0 0.0.0.0:0 [DHCP IP: 192.168.0.11] to MAC address 00:ee:bd:a9:99:39 1 Thu Dec 08 11:07:14 2016 0.0.0.0:0 0.0.0.0:0 [DHCP IP: 192.168.0.11] to MAC address 00:ee:bd:a9:99:39 1 Thu Dec 08 11:07:12 2016 0.0.0.0:0 0.0.0.0:0 [admin login] from source 0.0.0.0 1 Thu Dec 08 10:54:10 2016 0.0.0.0:0 0.0.0.0:0 [DHCP IP: 192.168.0.100] to MAC address 86:16:f9:a9:99:39 1 Thu Dec 08 10:47:43 2016 0.0.0.0:0 0.0.0.0:0 [DHCP IP: 192.168.0.19] to MAC address 86:16:f9:c9:51:b4 1 Thu Dec 08 10:30:40 2016 0.0.0.0:0 0.0.0.0:0 [DHCP IP: 192.168.0.19] to MAC address 86:16:f9:c9:51:b4 1 Thu Dec 08 10:30:39 2016 0.0.0.0:0 0.0.0.0:0 [DHCP IP: 192.168.0.19] to MAC address 86:16:f9:c9:51:b4 1 Thu Dec 08 10:30:32 2016 0.0.0.0:0 0.0.0.0:0 [DHCP IP: 192.168.0.19] to MAC address 86:16:f9:c9:51:b4 1 Thu Dec 08 10:30:29 2016 0.0.0.0:0 0.0.0.0:0 [DHCP IP: 192.168.0.18] to MAC address 86:16:f9:a4:79:58 1 Thu Dec 08 09:38:35 2016 0.0.0.0:0 0.0.0.0:0 [DHCP IP: 192.168.0.18] to MAC address 86:16:f9:a4:79:58 1 Thu Dec 08 08:49:01 2016 0.0.0.0:0 0.0.0.0:0 [DHCP IP: 192.168.0.18] to MAC address 86:16:f9:a4:79:58 1 Thu Dec 08 08:49:00 2016 0.0.0.0:0 0.0.0.0:0 [DHCP IP: 192.168.0.11] to MAC address 00:ee:bd:a9:99:39 1 Thu Dec 08 07:38:54 2016 0.0.0.0:0 0.0.0.0:0 [DHCP IP: 192.168.0.25] to MAC address 86:16:f9:0a:b2:3d 1 Thu Dec 08 07:03:48 2016 0.0.0.0:0 0.0.0.0:0 [DHCP IP: 192.168.0.100] to MAC address 86:16:f9:a9:99:39 1 Thu Dec 08 06:49:15 2016 0.0.0.0:0 0.0.0.0:0 [DHCP IP: 192.168.0.11] to MAC address 00:ee:bd:a9:99:39 1 Thu Dec 08 06:17:07 2016 0.0.0.0:0 0.0.0.0:0 [DHCP IP: 192.168.0.21] to MAC address 86:16:f9:97:2c:8a 1 Thu Dec 08 06:16:07 2016 0.0.0.0:0 0.0.0.0:0 [DHCP IP: 192.168.0.17] to MAC address 84:16:f9:99:2b:c3 1 Thu Dec 08 04:30:14 2016 0.0.0.0:0 0.0.0.0:0 [DHCP IP: 192.168.0.17] to MAC address 84:16:f9:99:2b:c3 1 Thu Dec 08 04:30:13 2016 0.0.0.0:0 0.0.0.0:0 - DarrenMSr. NETGEAR Moderator
Hello rob
Is this happening across all devices in the home? is it just on the wifi?
DarrenM
