LordIsafril
May 16, 2017Aspirant
Nighthawk AC1900 C7000 ongoing router issues
I purchased this particular router around May 1st of 2016. At the start of my internet service, I had great reception and the line signal was wonderful. Fast forward a few months and the connection wo...
LordIsafril
May 20, 2017Aspirant
DarrenM
May 24, 2017Sr. NETGEAR Moderator
Hello Lordlsafril
I see a lot of un correctables on your channels this may be a line issue or even the cable splitter is bad try removing the cable splitter if one is connected to the modem and go directly to the wall or try a different cable outlet if you are able. If this does not help you may want to have a cable tech come out and check the lines.
DarrenM
- LordIsafrilMay 25, 2017Aspirant
They checked the lines recently. Apparently the lines in our walls are 59 line which Comcast stopped using 12 years ago. Somone will be out to fix them. Currently, only weird thing going on is my upstream light is blinking but my internet is fine.
