alexis_thebass1
Mar 23, 2020Aspirant
Nighthawk AC1900 C7000 random disconnects every day- 2020 Edition
Hello all, Starting a thread again, since the other threads are too old to be commented on. It has been dropping the internet connection every day at the same time. Sometimes twice a day. Onl...
saurabhsen
Jun 18, 2020Aspirant
Very odd and I do not have any correct explaination why my c7000 started working again.
C7000 working without any disconnect in last 3 days. All I did was run it 1 hour with a low powered Netgear 12V 1.5A adapter from another device which worked fine. Since I read in many posts that it may be cause a fire when running with a low power 1.5A adapter (c7000 uses a 3.5A adapter) I changed it back to the original 12V 3.5A adapter and it did not drop connection in last 3 days. Power is now less compared to 51 dBmV in all 4 locked channels earlier when it was dropping connection frequently.
| Upstream Bonded Channels | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
I will post back if disconnect starts again. Thank you.
Jun 19, 2020Guru - Experienced User
Please mark your thread as solved so others will know.
Glad you figured it out.
Enjoy.
