notadingus
Apr 02, 2020Aspirant
Nighthawk ac1900 c7000v2 has significant packet loss and high ping in gaming and video calls
I am completely baffled by my internet problems right now. I used to have a different router modem combo from netgear that worked pretty well for me, but after 3 years I started noticing problems (I ...
Apr 03, 2020Guru - Experienced User
One way to find out is to turn OFF the wifi radios on the modem. Game over wired connection and see if you still see high ping. Turn off ALL other wifi devices in the home as well while gaming. Test and let us know.
notadingus
Apr 05, 2020Aspirant
Any other suggestions?
- FURRYe38Apr 05, 2020Guru - Experienced User
You might try a different modem, see if a different modem has the same problem or not. Then you'll know if the C7000 is the problem or not.
- notadingusApr 06, 2020Aspirant
I had a different Netgear router modem combo with a similar problem that only started happening a little more than a month ago, but I thought it was that router's problem. It wasn't since the problem is still happening, but since they were both Netgear, I was wondering if it could be a problem with a firmware update. My ISP has come to my place multiple times and my internet tests always look good to them, But the consistent lag and packet loss is continuing.
- FURRYe38Apr 06, 2020Guru - Experienced User
You might try a different branded modem, Arris or Motorola and see. You might go with a modem only unit and then get you a external wireless router.
