RND1023
Nov 12, 2022Guide
Nighthawk AC1900 C7000V2 Modem Router slow download speeds
I have 600 MBPS coming into the unit and if I get within 3' of it, I can get about 211 coming out via WIFI. That is with the Ookla speed testing. Unplugging it for a period doesn't change anything. F...
RND1023
Nov 13, 2022Guide
According to this post it appears to be a regular problem with this modem router unit.
Kitsap
Nov 13, 2022Master
RND1023 wrote:According to this post it appears to be a regular problem with this modem router unit.
c7000v2 Slow wifi speed - NETGEAR Communities
There are a lot of variables involved with the throughput capacity of a Wi-Fi connection. Placing blame on the modem/Wi-Fi router hardware would be relatively low on the list. At the top of the list would be the configuration of the Wi-Fi router, capacity of the device you are using to test, and the radio frequency environment where you are testing. The environment includes home construction material and interference from other Wi-Fi sources,
