RND1023
Nov 12, 2022Guide
Nighthawk AC1900 C7000V2 Modem Router slow download speeds
I have 600 MBPS coming into the unit and if I get within 3' of it, I can get about 211 coming out via WIFI. That is with the Ookla speed testing. Unplugging it for a period doesn't change anything. F...
RND1023
Nov 13, 2022Guide
My ethernet speed with a new cable & Ookla testing is about 94 with 2.4. I'm using my laptop.
Kitsap
Nov 13, 2022Master
RND1023 wrote:My ethernet speed with a new cable & Ookla testing is about 94 with 2.4. I'm using my laptop.
Your statement above does not make a whole lot of sense. New Ethernet cable connecting what to what?
Over the 2.4 GHz Wi-Fi band, a test throughput of 94 Mbps is not bad. How old is your laptop? What operating system?
Have you run a throughput test using your laptop connected to the 5 GHz band?
- RND1023Nov 13, 2022Guide
All right. Connecting the modem router to the pc via an ethernet cable connection then running the Ookla speed test on the 3- or 4-year-old HP updated windows 10 pc model #15-au063nr. Can't run 5GHz with ethernet. Have previously posted 5GHz Wi-Fi speed. Within 3' of the modem router I got a 211, within 6' of the modem router I got 198 with the Ookla speed test. The Exfinity speed test isn't worth the effort to run.
I previously said I had 600 coming in, I am wrong there, it is 400. How can 94 going out be "not bad", when you have 400 going in? That doesn't make sense either.
- KitsapNov 13, 2022Master
RND1023 wrote:All right. Connecting the modem router to the pc via an ethernet cable connection then running the Ookla speed test on the 3- or 4-year-old HP updated windows 10 pc model #15-au063nr. Can't run 5GHz with ethernet. Have previously posted 5GHz Wi-Fi speed. Within 3' of the modem router I got a 211, within 6' of the modem router I got 198 with the Ookla speed test. The Exfinity speed test isn't worth the effort to run.
The throughput coming in is over the cable. I agree the Xfinity test is not worthwhile. Stick with Ookla.
What you have coming in over cable is what you should have going out over Ethernet to a computer. You will not see that over Wi-Fi. If you have Wi-Fi in at the computer at 100 Mbps over the 2.4 GHz band that is good. If you have Wi-Fi in at the computer at 300 Mbps over the 5 GHz band, that is good.
Recommended reading to help you understand Wi-Fi. https://www.duckware.com/tech/wifi-in-the-us.html
Does your laptop have an Ethernet input port or is it Wi-Fi only?
- RND1023Nov 14, 2022Guide
Thanks for the article it's amazing.
- plemansNov 14, 2022Guru - Experienced User
Check your hardwired pc/laptop to see if its actually connecting at gigabit speeds. When you hit 94mbps it usually means you're only connecting at 10/100mbps speeds and not gigabit. And you're hitting faster over 5ghz so the modem is supplying more speed.
https://kb.netgear.com/24222/How-do-I-display-Internet-port-statistics-on-my-Nighthawk-router
Here is a screen shot.
