RND1023
Nov 12, 2022Guide
Nighthawk AC1900 C7000V2 Modem Router slow download speeds
I have 600 MBPS coming into the unit and if I get within 3' of it, I can get about 211 coming out via WIFI. That is with the Ookla speed testing. Unplugging it for a period doesn't change anything. F...
Kitsap
Nov 13, 2022Master
RND1023 wrote:All right. Connecting the modem router to the pc via an ethernet cable connection then running the Ookla speed test on the 3- or 4-year-old HP updated windows 10 pc model #15-au063nr. Can't run 5GHz with ethernet. Have previously posted 5GHz Wi-Fi speed. Within 3' of the modem router I got a 211, within 6' of the modem router I got 198 with the Ookla speed test. The Exfinity speed test isn't worth the effort to run.
I previously said I had 600 coming in, I am wrong there, it is 400. How can 94 going out be "not bad", when you have 400 going in? That doesn't make sense either.
The throughput coming in is over the cable. I agree the Xfinity test is not worthwhile. Stick with Ookla.
What you have coming in over cable is what you should have going out over Ethernet to a computer. You will not see that over Wi-Fi. If you have Wi-Fi in at the computer at 100 Mbps over the 2.4 GHz band that is good. If you have Wi-Fi in at the computer at 300 Mbps over the 5 GHz band, that is good.
Recommended reading to help you understand Wi-Fi. https://www.duckware.com/tech/wifi-in-the-us.html
Does your laptop have an Ethernet input port or is it Wi-Fi only?
RND1023
Nov 14, 2022Guide
Thanks for the article it's amazing.
