RND1023
Nov 12, 2022Guide
Nighthawk AC1900 C7000V2 Modem Router slow download speeds
I have 600 MBPS coming into the unit and if I get within 3' of it, I can get about 211 coming out via WIFI. That is with the Ookla speed testing. Unplugging it for a period doesn't change anything. F...
Nov 14, 2022Guru - Experienced User
Because we want to see if you're actually getting the speeds you pay for. You won't max them out wireless but wired you should be able to. Its pointless to troubleshoot why your wireless is only getting 200mbps if you're modem is only outputting 200mbps because of a poor connection or bad provisioning.
RND1023
Nov 14, 2022Guide
I guess that means you would like to see those specs?
