cadguy82
Jul 17, 2021Aspirant
Nighthawk AC1900 Cable Modem Voice Router
NetGear Nighthawk AC1900 Cable Modem Voice Router Model: C7100V-100NAS NetGear genie Firmware: V2.01.33 USB Connections: HP P1006 Printer Free Agent Drive Have NetGear USB Control Cente...
cadguy82
Aug 24, 2021Aspirant
I have powered off all devices for more than 5 minutes but the result is the same.
I have executed a factory reset and the result is the same.
The firmware cannot be updated. When I go to the download area and put in model number, it says
- Firmware/Software not available for this model.
I even found a different printer and connected it but the result is the same.
I have attached 2 screen shots of ready share from the Gateway for the router.
The top one is ready share showing no USB storage even though a drive is connected.
The bottom one is after I select the ready share printing, the screen comes up as if no printer is connected even though one is.
This may mean nothing but, if the printer was turned off, I could not access the USB drive. If the power went out for any period of time long enough for the printer to shut off then came back on, I could not access the USB drive until I turned the printer on.
This worked fine before and nother has changed. I'm beginning to wonder if the USB part of the router is bad.
