Beetr00t
Feb 20, 2018Tutor
Nighthawk AC1900 dropping 5ghz broadcast
My Nighthawk AC1900 recently stopped broadcasting the 5ghz channel. 5ghz is still enabled in settings. If I reset the router the 5ghz channel will reappear for a bit, but none of my devices can connec...
Beetr00t
Feb 21, 2018Tutor
Thank you antinode. Sorry for the mididentification of model number, I grabbed that from the Amazon product page.
Model C7000
Firmware v1.01.28
I did a full factory reset of settings and the problem persists. I called Netgear customer support and they told me it was a software issue that they "could easily fix in less than 15 minutes remotely" but that since the product is out of their 3 month warranty, it would be $149.99 for them to fix it. Pretty disgusted with Netgear at the moment.
antinode
Feb 21, 2018Guru
> Model C7000
Ok. Forget about updating your firmware (yourself). For cable-TV
modem(+router)s, the ISP has exclusive control over that.
There have been multiple reports of wireless problems, on multiple
devices, caused by lame firmware, so there is still a chance that fresh
firmware will help.
- Beetr00tFeb 22, 2018Tutor
Gotcha. Well that's unfortunate. I went ahead and bought a new modem and router from TP Link. It's up and running great with equal range and speed for half the price. I know software/firmware issues happen with all devices all the time, but Netgear was so miserable to deal with I'll never buy their products again.
Thank you so much for your help antinode I really appreciate it.
