EBXHOMM
Jun 28, 2017Aspirant
Nighthawk AC1900 R7000 Questions
I have a question: My wife bought me a AC1900 Smart router (DOCSIS3.0) because it is compatible with Xfinity. I told her I may have a problem because I have the AC5300 router. Can the two be u...
EBXHOMM
Jun 30, 2017Aspirant
Sorry, you are right. The C7000 is the cable modem/router and the R8500 is my router. CAn I use both even though the AC 1900 (R7000) is a cable modem/router? Would it be an issue having two modems in the home network or should it work fine?
DarrenM
Jul 03, 2017Sr. NETGEAR Moderator
Yes you can I would suggest to make the C7000 in modem only mode so routing conflicts do not happen.
DarrenM
- EBXHOMMJul 05, 2017Aspirant
I am assuming there are instructions on making the cable modem/router as modem only online, correct? If so, thanks for the tip.
- michaelkenwardJul 05, 2017Guru - Experienced User
