Gotmilkman
May 26, 2019Aspirant
Nighthawk AC1900 telnet
I purchased this modem/router combo last year and I was able to get into the modem and add a static ip+mac with telnet. The modem has been reset and I havenot been able to get into it as of now. I'm t...
May 28, 2019Guru - Experienced User
Do you mean setting a reserved IP address ON the modem for the PC? Static is a IP address that is set ON a device, not the router.
Can you access the modems web page at 192.168.100.1 or .0.1?
- GotmilkmanMay 28, 2019AspirantYes I can access it and reserve the ip, but the problem I'm having is the table that holds all the active ip addresses clears any non-active ip after 15 minutes. I need to be able to access it via telnet to add an arp command to hold that up+Mac address until the modem/router is reset. (Static) that way when I try to wol outside of my network it will find my computer.
- FURRYe38May 28, 2019Guru - Experienced User
And you can't get telnet working? Some modems don't support telnet.
Try to see if you can access 192.168.0.1\debug.htm, If you can get here, there maybe a telnet check box. Enable the check box then telnet will be enabled for access.
- GotmilkmanMay 28, 2019AspirantYep that's my problem is I can't access it anymore. For whatever reason I was able to do it last year and I can't this year. The telnetenable.exe says telnet should be working when I use it, but no cigar.
