Gotmilkman
May 26, 2019Aspirant
Nighthawk AC1900 telnet
I purchased this modem/router combo last year and I was able to get into the modem and add a static ip+mac with telnet. The modem has been reset and I havenot been able to get into it as of now. I'm t...
May 28, 2019Guru - Experienced User
Do you mean setting a reserved IP address ON the modem for the PC? Static is a IP address that is set ON a device, not the router.
Can you access the modems web page at 192.168.100.1 or .0.1?
Gotmilkman
May 28, 2019Aspirant
Yes I can access it and reserve the ip, but the problem I'm having is the table that holds all the active ip addresses clears any non-active ip after 15 minutes. I need to be able to access it via telnet to add an arp command to hold that up+Mac address until the modem/router is reset. (Static) that way when I try to wol outside of my network it will find my computer.
- FURRYe38May 28, 2019Guru - Experienced User
And you can't get telnet working? Some modems don't support telnet.
Try to see if you can access 192.168.0.1\debug.htm, If you can get here, there maybe a telnet check box. Enable the check box then telnet will be enabled for access.
- GotmilkmanMay 28, 2019AspirantYep that's my problem is I can't access it anymore. For whatever reason I was able to do it last year and I can't this year. The telnetenable.exe says telnet should be working when I use it, but no cigar.
Possbible that NG/ISP updated the FW on the modem and disabled telnet access. I know ISPs closed a security issue a year or two ago with some modem not having a web page access PW and they removed the reboot function on some modems. Possible that telnet access was removed for security reasons. One gets in thru telnet and things could get bad.
You may need to bridge the modem and connect up a NG R series router that supports telnet. Most R and XR and RAX series routers support telnet.
