allgored
Feb 12, 2021Aspirant
Nighthawk AC1900 Wifi Cable Modem Router (C7000v2) - Cannot see option to upgrade firmware
I am able to connect to the internet just fine. But I downloaded the NighHawk app and it says that the firware is out of date and I should open routerlogin.net. I am able to see the routerlogin....
labatt
Feb 12, 2021Mentor
You will not see and options to upgrade the firmware. Firmware upgrades are done by the ISP when you are using a cable/modem router. Down side of running a combo modem router. In most cases that I have seen an update never happens. I have used netgear modems on Comcast and never saw a firmware update even though if you look at the Netgear site there is an update. I don't worry about it as long as things are working.
- allgoredFeb 12, 2021Aspirant
Ah gotcha! Makes sense
