kathyyar
Oct 24, 2022Aspirant
Nighthawk AC1900 Wifi Cable Modem Router works with ATT fiber in passthrough mode
Guys, I just want to know if my model Nighthawk which I purchased for use with Xfinity can be successfully setup with ATT Fiber internet. I am trying to use the passthrough function on the BGW 210 (...
- Oct 24, 2022
No. the C7000 is a cable modem only. It won't work with your fiber connection.
Potentially you can get it to function as a type of access point but not as a router.
You can try the guide here if you'd like:
Oct 24, 2022Guru - Experienced User
kathyyar
That's what I "thought" but I really appreciate your response. I worked on it last night and it appeared to be a no go....
You have saved me lots of time!
